Ok Hope we had a nice weekend. Only had about 2 hrs time to work on it this morning before i had to go out
I have fitted the humdinger and yes an improvement
Fitted a 470R LOG Pot across the heaters with the wiper of pot going to ground. Disconnected the TX CT.
when i turn on with all volumes turned down and adjust the 470R pot. i can adjust for quite, once i turn up the volumes noise is there. If i then adjust the 470R i can remove the noise but then it will be noisy on another channel
Too cut a long story short if i adjust the 470R for every channel i can get it quite
I have connected the wiper of the pot to various different grounds inc to the EL84 no difference
At this point i'm thing of separating some of the grounds to different points as all are going to the same Star gnd
idea's
many thanks
Arbutt
idea's
many thanks
Arbutt
