Source for odd pots
These might work. Just cut off the metal mounting bracket and add some spacer washers.
https://www.fullcompass.com/prod/161...t-b-for-mb150e
https://www.fullcompass.com/prod/243...for-mb150e-amp
Originally posted by Axtman View PostThese might work. Just cut off the metal mounting bracket and add some spacer washers.
But along the same lines...
I'm in favor of substitution also. It's just a pot. There are surely 12mm pots in the right values/tapers with a shaft that could be corrected with washers. Looks to be PC pins there. Nearly all pots follow standard pin spacing specs. I'll grant that it's been harder some times than others, but I've retrofitted pots many times to get around some odd, proprietary part.
"Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
