Sunn 200S Power Supply Help
  • #31
    Measure ripple voltage at each end of the choke. There should be a significant difference before and after the choke.
    6.14 VAC before choke
    0.37 VAC after choke
    • #32
      Bare with me, I am not used to using the scope. Perhaps I am not setting it correctly. At 5ms I have too many peaks. At 5us I was able to get it to two peaks.
      Here is 5ms image.
      • #33
        Here is 5ms image.
        Ok, so we have 120Hz ripple with superimposed HF oscillation. Is this with volume at zero?
        • #34
          Choke is good.
          • #35
            No, volume was up, not sure how high. Two new pics below with volume at zero and volume at 5.
ID:	930466 Click image for larger version
            • #36
              Judging from the left picture, there should be no hum with vol. at zero?
              (Actually the first thing I'd do is rewire the amp for a GZ34.)
              • #37
                Yes no hum at zero volume. This is getting more bizarre. Hooked the speaker back up (was on a dummy load). I have a probe at the first filter cap watching DC. Guitar plugged in.
                Amp is producing bizarre noises (like blowing into a trumpet mouthpiece, I will call it high pitch squealing) that is jumping all around in frequency. I am also seeing the voltage at the first filter cap fluctuating up and down in sync with the weird noise, from 100 to 350 V. Layered behind this noise I can still hear the 120 cycle hum.
                Eventually the V at the first cap drops to 90 V and the squealing stops, while the hum is still there.
                Regardless of the V at cap 1, I can still strum and clearly hear the guitar.
                Yikes!
                • #38
                  Well, you have an oscillation problem probably with the 12AX7. Have you tried a different tube?
                  What happens with V1 pulled and full volume?
                  • #39
                    V1 pulled, no noise or hum heard at full volume. Swapped V1 and I and no longer hearing squealing sounds.
                    I am left with just a slight hum at loud volumes. Louder than I would ever play. Possible this is due to mismatch output tubes current?
                    In monitoring the voltage at the first cap (about 555 V) once in a while it drops to 97 V. I think the wiring connections between the rectifier, standby switch, and first cap needs to be touched up with solder. If I poke around at those joints the 555 V will come back. Also I detect a small squeal when poking the wire between the standby switch and first cap.
                    I also wonder if I should use a dropping resistor to knock that 555 V closer to 500 V?
                    I feel I am getting closer to resolution.
                    • #40
                      Rewire to GZ34, will lower B+ as well as hum.
                      But check if you still have ultrasonic preamp oscillation.
                      • #41
                        Looks like it is still there. Scope images below volume 0 and volume at 5.
ID:	930501 Click image for larger version
                        • #42
                          Go to 5µs/div for better HF resolution.
                          • #43
ID:	930512 Click image for larger version
                            • #44
                              So there's still some ultrasonic signal (around 42kHz).
                              Could be either an oscillation of V1 or a signal picked up from nearby equipment (switching power supply, phone etc.).
                              • #45
                                Interesting. Beyond human hearing. Will see what I can figure out.
                                Thank you!
