Sure, you’re not wrong. I more meant trying to scrape oxidation off with a knife - that’ll work for a minute but if the tip has already gotten that bad, it’s close to the end of its life.
I found better tip life cleaning with brass than I did with a sponge. That’s a quick plunge into the brass to remove excess solder after each joint, not scraping and sanding away the tip aggressively.
