You've previously established the Preamp works. So I assume we can leave it alone. You've been working on the Power Amp assembly. From the system side of things, your path is Thru the Vacuum Tube front end to the two halves of the Bridged Pair Power Amp. Do either of the halves work....does it pass signal to full output swing, where it clips? What happens when you follow the notes on the schematic? Input level is given. Levels that follow are based on that, given in V p-p to be read on your scope. Are you getting these levels? If not, why not.?
Ampeg SVT-6 Pro No Output
Originally posted by nevetslab View PostYou've previously established the Preamp works. So I assume we can leave it alone. You've been working on the Power Amp assembly. From the system side of things, your path is Thru the Vacuum Tube front end to the two halves of the Bridged Pair Power Amp. Do either of the halves work....does it pass signal to full output swing, where it clips? What happens when you follow the notes on the schematic? Input level is given. Levels that follow are based on that, given in V p-p to be read on your scope. Are you getting these levels? If not, why not.?
1 Photo
Originally posted by ca7922303 View PostTest points per schematic. Showing both ends on some.
When @ 11v and 20v pp, clipping light was on constant.
You had previously stated the Preamp is working fine. When you see the RED CLIP light lit up, are you seeing CLIPPING in the Power Amp....at 11V P-P and 20V P-P?
Across J32/J33 @ 20V PP(0.8 mv)
Earlier you show around 20mA thru the relay driver's collector resistors R46, R33, each being 1.5k/5W. So there is DC current flowing thru the relay coils for that to occur. I looked on their parts list, and see these relays are 24VDC Coils Yet you are NOT getting signal thru the relay. The relay contacts are either at GROUND potential or in contact with the Output busses.
I would unsolder the relays, and power them externally to verify each opens and closes when you energize the coils. With a 24VDC coil, you can usually get them to turn on and off with 18VDC, maybe even 15VDC, though would be weak contact. Can you do that? When unenergized, do you read 0 ohms between pins 1 and 5 of each relay, and energized, do you read the same 0 ohms between pins 1 and 4? You should hear the relay click when you energize it on/off.
Last edited by nevetslab; 07-30-2022, 01:40 AM.Logic is an organized way of going wrong with confidence
If I understand this correctly (you have 20V PP on the outputs, meaning each buss is 10V P-P, and signal is opposite polarity on the second half output, so you have 20V P-P), and you're getting 0.8mV across J32/J33.....
R110 and R111 voltages should be close to same. Seems R110 voltages (and R4) are off.
Also, DC voltages should be measured without signal.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
AS ALL of the Clip LED drive points are in the Preamp, and I DO NOT see drive points (that liittle 'Boxed' letter P) that are everywhere in the Preamp circuits, both at tube stages as well as op amp stages thruout the Preamp), I have to conclude you're driving the power amp stage thru the preamp. What happens if you drive it from the Power Amp input jack?
Originally posted by g1 View PostI was thinking the .8mV at J32/J33 was the DC there. It would be better if more details were noted.
