1980's Marshall Bass 12 - Hum Problem
    Originally posted by The Dude View Post
    Do you have a scope?
    I'm intrigued about using a scope to identify the problem. I'd presume that you feed a signal into the amp with a sig gen, then examine the waveform at various points along the signal path until you find where the hum is introduced into the circuit? Not sure if I have oversimplified this! If you could talk me through the basics of how to connect it up, suggested locations along the path to check etc. I would be very grateful.
    Usual caveat applies regarding high voltages, extreme caution, not ending up being a charred and smoking guitarist on the end of a probe connected to the scope etc.
      No sig gen required here as the hum is your signal.
      Start with scoping the speaker output.
      Also make sure there's no DCV across the output.
        I've just dug out the wife's scope - haven't plugged it in yet, so don't even know if it works. So when you say make sure no DCV across the output, I have connected my multimeter across the speaker wires and I'm getting the reading on the photo. Doesn't vary when I twiddle volume or gain knobs, or when I plug a lead in. Forgive my absolute newbie questions, but what is this telling me?
          It's saying there's a -100mV offset on the output which is OK.
            ok - great! I've connected the scope to the output, but I'm not really sure what I'm supposed to be looking at!
              Hi,
              Just wanted to add that the official schematic for the Bass 12 can be found here:
              https://music-electronics-forum.com/...l-bass-12-5501
