oh mesa, you've done it again!
  • oh mesa, you've done it again!
    Got a Dual Rectifier Solo head that won't recognize the footswitch once warmed up, or switches to the orange channel which is the default when the rear switch is set to Foot Switch with no switch attatched.
    I'm "pretty sure" the switch is the problem, it sits below the output tubes and it and the ribbon cable are getting very hot.
    Fiddling with it causes it to work properly and recognize the foot switch, BUT.... true to mesa form, it's a PIA to get to.
    You need to remove the board above it and it looks like the output tube board also.
    great how they cram all this stuff in these.
    The WWII generation had a word for this: blivet. 10 pounds of $#!+ in a 2 pound sack.
      New Mesa Logo?Click image for larger version  Name:	Blivet.jpg Views:	0 Size:	137.7 KB ID:	940080
        Originally posted by The Dude View Post
        New Mesa Logo?]
        Funny t'ing I typed but then edited before posting "Imma start new amp company, makes Far East copies of these. And call it Blivetone."
        I see graphic is set for hevvy mettul scoop tone.
        Good work Dude, I'd give you a thousand likes if I could.
          I work in Petaluma, the home town of Mesa Engineering.
          Rumor has it their first name originally had 2-S's
            Great drummer we had was in a band called Blivet!
            Luckily was able to get to the switch by just removing the long jack board above it and fix the switch and cable.
            Four hours later it's still working okay.
Name:	82440181_2622542097978524_2228615133544841216_n.jpg?_nc_cat=106&ccb=1-5&_nc_sid=9267fe&_nc_ohc=XoHBarU3No0AX_n6fD5&_nc_ht=scontent.fbeg2-1.fna&oh=a058ddd8e456172afd7ecba907b83fb4&oe=6150F68F.jpg
              https://www.facebook.com/Blivet69/
              It's All Over Now
                Different band.
                  Different band.
                  Goes to prove, one blivet is never enough. Important advice: don't mix up your blivets!
