Traynor guitarmate reverb YGM-3 power transformer replacement.
  • Traynor guitarmate reverb YGM-3 power transformer replacement.
    I picked up a cosmetically challenged 1971? Traynor ygm-3. (The version with the three input jacks) It has been spray painted, the baffle board was hacked up for a 15 inch speaker, and there is almost none of the print is left on the faceplate. Right now the biggest issue is that it is missing the power transformer.
    I did a little research and I believe the a Hammond 290TRB is the correct replacement.
    However, I found a few sources that suggest using a Hammond 270DAX to lower the plate values for modern AC voltage and EL-84 tubes. (http://leightonamplifiers.blogspot.c...well-that.html)
    My home AC voltage is 123V
    I have to buy a transformer, so I just wanted to get some opinions about which way to go.
    Specs:
    https://www.hammfg.com/files/parts/pdf/290TRB.pdf
    https://www.hammfg.com/files/parts/pdf/270DAX.pdf
    I found these decals for the faceplate but I would welcome any other suggestions
    https://www.radiodaze.com/generic-gu...tem-dcl-gamp1/
    Thank you to all for your advice.
    I also like the 270DAX specs better. But it has a bit smaller footprint, so if the 290TRB is an exact fit, you will have to drill some holes to use the 270.
      ah ha..I have that amp here that I had bought brand new in the 70's.... did you try Yorkville for a transformer?? they still make some of these vintage amps as re-issues...call Yorkville....1-905-837-8550...ext 236....
        That is a great sounding little amp. I used to use one for reggae band practice in the 90's. The bass player never would sell it to me.
          Thank you for your rely G1, I think I try the 270DAX. I might need some help figuring out how to use the center tap as was mentioned in the link I posted. I am assuming two diodes are removed to set up a full wave rectifier, but I do not completely understand hooking it up.
          Randall- I am looking forward to hearing it when it is done. If I get too over my head it will likely end up on your bench.
            Originally posted by Chemtooler View Post
            I might need some help figuring out how to use the center tap as was mentioned in the link I posted. I am assuming two diodes are removed to set up a full wave rectifier, but I do not completely understand hooking it up..
            If your amp corresponds to the schematic you posted, there are only 2 rectifier diodes and the replacement PT is connected just like the original one.
              Thank you Helmholtz, you are correct that is not the correct schematic. The diodes in this one are arranged like the first schematic in this link. Dated 11/73
              https://www.thetubestore.com/lib/the...-Schematic.pdf
                The link in post #1 was about a 1978 version? He is talking about a bridge rectifier that your amp does not have.
                  Here is a picture of the power section
Name:	Traynor YGM3 pic 1.JPG
                    Sorry, I didn't see right off that there was a multi-page schematic.
                    Your amp power section uses the full wave rectifier with the center-tap going to the standby switch.
                    The unit described in the link you posted had a bridge rectifier like the 1998 re-issue. (see attached)
