I picked up a cosmetically challenged 1971? Traynor ygm-3. (The version with the three input jacks) It has been spray painted, the baffle board was hacked up for a 15 inch speaker, and there is almost none of the print is left on the faceplate. Right now the biggest issue is that it is missing the power transformer.
I did a little research and I believe the a Hammond 290TRB is the correct replacement.
However, I found a few sources that suggest using a Hammond 270DAX to lower the plate values for modern AC voltage and EL-84 tubes. (http://leightonamplifiers.blogspot.c...well-that.html)
My home AC voltage is 123V
I have to buy a transformer, so I just wanted to get some opinions about which way to go.
Specs:
https://www.hammfg.com/files/parts/pdf/290TRB.pdf
https://www.hammfg.com/files/parts/pdf/270DAX.pdf
I found these decals for the faceplate but I would welcome any other suggestions
https://www.radiodaze.com/generic-gu...tem-dcl-gamp1/
Thank you to all for your advice.
Specs:
