Kalamazoo Model One Switched Input Jack
  • Kalamazoo Model One Switched Input Jack
    I am getting a 60 cycle hum on my Model One unless I plug in a guitar. Then it goes away.
    I thought that the switched input jack # 1 is suppose to ground the input. I cannot figure out why it does not. The switch blade and tip blade have good contact. The ground terminal has a good connection to ground. I sanded away the paint inside the chassis at the jack.
    If I jump a wire from the input blade to ground there is no noise.
    What am I missing or doing wrong?
    Thank you, MC
    Click image for larger version  Name:	kalamazoo-model-one.jpg Views:	0 Size:	318.0 KB ID:	946401 Click image for larger version  Name:	IMG_20211203_162742637.jpg Views:	0 Size:	721.9 KB ID:	946402 Click image for larger version  Name:	IMG_20211203_162748179.jpg Views:	0 Size:	1.44 MB ID:	946403
    Remove the insulated washers from the input jacks. Theyre not shown in the schem. Nor is a switched jack .
    nosaj
      J1 is drawn as a switched jack. I agree we do not want insulating washers on the jacks.
        My mistake. I also could be wrong about the washers they look like insulated washers but I guess patina on a toothed washer could look similar. OP will have to tell us.
        nosaj
          No insulated washers, those are metal washers with teeth. I removed it from jack # 1 and I still do not have continuity from the positive blade to ground.
            I would fit a 3 core mains lead and place the earth on the spare solder tag then connect a wire from the bare flex shown between the two input sockets and the same tag as shown.
            Click image for larger version  Name:	Screenshot 2021-12-03 at 22.14.48.png Views:	0 Size:	1.77 MB ID:	946416
            Then remove this thing with an orange line on it we call a death cap.
            Click image for larger version  Name:	Screenshot 2021-12-03 at 22.10.17.png Views:	0 Size:	1.16 MB ID:	946417
            Then fit a switched socket in the right hand jack, the switched contact is missing!
            Keep safe.
              Are those switched jacks suppose to have 3 lugs? I only have 2 lugs.
                Keep safe.
                Will do. Thank you
                  It's the correct shorting/switching jack but the middle lug seems to be broken off and missing. Should be connecting to chassis ground.
Name:	Screenshot 2021-12-04 at 09.40.33.png
ID:	946496 Switched lug is missing.
                      Another curiosity to me, input jack # 2 ground lug has a white wire connected to pin 9 of the 12AX7. This is the heater center tap. I do not see in the schematic where it should be connected to ground.
                      However I think I see this wire in a picture of another Kalamazoo. Looks like in that one a wire runs from jack # 2 ground through jack # 1 blade lug to jack # 1 ground lug to 12AX7 pin 9.
                      Thank you
                        All working now. Thank you all for the advice. Picture shows what I ended up doing with the 3 prong and the corrected input jack. MC
