I am getting a 60 cycle hum on my Model One unless I plug in a guitar. Then it goes away.
I thought that the switched input jack # 1 is suppose to ground the input. I cannot figure out why it does not. The switch blade and tip blade have good contact. The ground terminal has a good connection to ground. I sanded away the paint inside the chassis at the jack.
If I jump a wire from the input blade to ground there is no noise.
What am I missing or doing wrong?
Thank you, MC
Thank you, MC
