Jon... 99% ok. are you talking about the main power transformer? ... ok so i isolated the output transformer and did some basic loose OT multimeter resistance/continuity tests including:
- secondary to secondary ohm: .4 ohm
- primary to secondary continuity: none - good
- all wires. shorts to case/ground: none - good
- resistance between the primary red wire and blue/brown wires - weird?
i think all looks normal except for the resistance between the primary red wire and blue/brown wires. i am getting a very low ~4ohm reading from red to blue and also red to brown. from what i have seen this should be higher ~100ohm range? is what i'm seeing not normal? thanks for baring with me on this. i bought the amp to learn but i was hoping to just do a basic check up of the amp while in working condition
