I getting static sort of hum from my Mesa and my rig is not even plugged into. I have twenty plugged into the same power with hospital grade receptacles. Tested on other circuits and the noise comes and goes but more frequent as it gets warmer. I not sure its EMI it happens in other jam rooms outside of mine. I checked the tubes seemed to be fine but I am not pro by any stretch. Any thoughts? See the attachment. Appreciate your time and Thanks
Mesa Single Rectifier Mystery noise
I would swap tubes one at a time as a first check. Of course it could be any number of things, but that sound makes me suspect tube(s). You say you "checked the tubes". I'm not sure how, but visual inspection, or even a tube tester, will not tell you much."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Thanks, I checked them visually didn't see any burn or any type of arc when turning it on. I really appreciate your quick reply and I think I was just looking for some reassurance to change the tubes. Off to the music store one of my favorite things to do as well. Much appreciated , I think the ol girl is due for a new set anyway. Thanks.
Any brand tube can come up noisy. It is often that someone tries different tubes, looking for ones less noisy or less microphonic or that just sound better when overdriven. Nothing wrong with mixed brands of tubes.Education is what you're left with after you have forgotten what you have learned.
This^^^^^^^^^^^^^^^^^^^^^
Preamp tubes serve individual functions in the amp and there's generally no reason for "matching". Quite the contrary in fact. While power tubes should be of the same brand and hopefully batch. If not actually "matched"."Take two placebos, works twice as well." Enzo
