Originally posted by mhuss
View Post
I'm just getting started with the client in handling their service needs in the LA area, or possibly on the West Coast as was originally stated. I've only looked at/heard four of their current products, and every one of them has this rectifier buzz spikes on the output, and thus far, only thing I've found to cure it is adding a humdinger to null out the rectifier buzz. Then had to sort thru different ECC83S and 12AX7 tubes from various mfgrs to find one that yielded the lowest noise and minimal hum. The J/J ECC83S, being the selected tubes for their preamps stages in this instance wasn't as good as some other tubes. I've been told this is related to the tube's cahthode/heater capacitance. Once the humdinger pot was in place and adjusted, THEN I found swapping in different tubes yielded surprisingly different results. J/J wasn't the best choice there.
