Bugera G20 Infinium sounds bassy
  • Bugera G20 Infinium sounds bassy
    Got used Bugera G20 Infinium amp, in perfect factory condition, but it does not sound anything like other people amps on Youtube. Talking about Distortion channel. I even put new tubes, it got a little better but stil not good, missing clarity and presence. Opened it up, everything looks pristine, and new. Any expiriences or ideas???
    Em.... this is an amp head, correct? And if yes, have you tried a different speaker (or speaker cab)? Just want to make sure the speaker itself is not overly "bassy."
      Yes it's a head, I am playing it on 2x12 cab with Celestions V30. I am going to try on a friends cab tonight which is mix of V30 and G12T-75. But stil people used it on Youtube with same speakers as mine and it sounded sharper :-(
Name:	Screenshot 2022-04-14 at 18.20.09.png
ID:	958197 Removing C67 from the notch filter will substantially increase the treble frequencies. You may need to fit a 47pF capacitor in there.
          Thanks for the idea, I got the amp to sound decent with putting EQ in the loop, I will try removing C67 if I keep the amp, to see how that works :-)
            C67 is an SMD style component but I can careffuly take care of that I believe.. I hate these new amps, I so loved amps where everythng was bigger and accessible
              Use desolder wick and remove as much solder as you can, Use a pair of small pliers and with a twisting action, twist off the capacitor.
              Or, if your soldering iron has a chisel bit, use plenty of flux and heat up the complete capacitor. It will almost instantly come away.
              Clean the board afterwards with IPA and a cotton bud.
