Hi,
I have a Behringer V-Tone GMX110 here that is driving me crazy, I am trying to fix it for a friend (I realise it’s probably not worth the time or parts, but it’s become a point of principle now! + I am learning things in the process...)![Big Grin](https://music-electronics-forum.com/core/images/smilies/biggrin.png)
When he gave it to me it blew the fuse shortly after being turned on every time, I disconnected the lead from the transformer to the amplification board and it stopped bowing the fuses. I quickly checked all the resisters in circuit and they all seemed to be ok ish, the caps seemed visually ok, (didn’t fancy desoldering them all to test at that stage) but the amp IC (TDA2050V) was shoring across a few of the pins so I ordered a new on with some new 7815 & 7915 voltage regulators at the same time...
With the new IC chips in, it powered on with the Amp board connected but the TDA2050V got very, very hot very quickly and it was pushing 20vDC to the Speaker output.
Shortly after that the new TDA2050V exploded...
I took some measurements on the TDA2050V mounting point with the TDA2050V removed and got the following:-
Pin1 (Non Inverting Input) 20V (steadily dropping)
Pin2 (Inverting Input)
Pin3 (-Vs) -34V
Pin4 (output) 0V
Pin5 (+Vs) -10V
I also took some measurements on the voltage regulators, I can’t honestly remember whether it was with the TDA2050V installed or not (sorry it was a week or so ago, lesson learned on note taking..)(Most likely not installed though...)
7915
Output -25V
Input -39V
Ground -8V (dropping)
7815
Output +6.9
Ground -6V
Input 17V
I then gave in and started unsoldering all the Caps & Diodes to test out of circuit, and this is what is doing my head in... I can’t find a big fault with any of it...
Some of the very,very small caps on the underside of the board I didn’t remove to test, but I had removed just about everything else by this stage and they gave sensible readings on the multimeter cap test in circuit, the only one of the tiny ones I did remove (because it wouldn’t give a reading in circuit) was C42 which gave 208nF when removed. (I can’t read the printing on the board to see what that one should be, but I took any reading on that one as a semi positive sign...
All the other caps are within tolerance as far as I can tell, but C7, C8 & C9 seemed way high...
C7 = 133 nF
C8 = 133 nF
C9 = 135 nF
According to the board they should be 100 nF and they were marked as +-2% tolerance
Could they be causing the problem? Seems a bit subtle to me....![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
The 5402 Diodes (D1 to D4) seemed ok with the following readings on the voltage drop:-
0.5644v
0.5823v
0.5294v
0.5814v
Resistor R1 is also a little high, reading 4.63 ohms (should be 4.2 ) which is out of its +/-5% tolerance, again could this be the problem?![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
C4, C5,C12 & C13 are little rectangular caps marked 100nJ100 they read 101.30, 101.69, 103.39 & 102.35. I don’t know what the tolerance for these should be as I can’t find a datasheet, but they don’t seem too bad...
Any Ideas folks? This is driving me utterly crazy, I spent a few hours browsing past threads on here to glean some clues, but I couldn’t find anything quite like this, but I did work out that you seem an amazingly knowlagable bunch & if anyone might know it would be you guys...
Many, Many thanks for taking the time to read this..
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Nick
Pin3 (-Vs) -34V
Pin4 (output) 0V
Pin5 (+Vs) -10V
7915
Output -25V
Input -39V
7815
Output +6.9
Ground -6V
Input 17V
C7 = 133 nF
C8 = 133 nF
C9 = 135 nF
0.5644v
0.5823v
0.5294v
0.5814v
Nick
