Schematic attached. Seems to be a lot of articles on this issue which I have yet to read but I will. So this is a common issue?
I am bringing back to life a 1961 Gibson GA-8T. I acquired it with no OT and a rats nest of PS caps installed. I took out the rats nest and installed new PS caps to spec consisting of a 22 uF, 10 uF, and 10 uF, all rated at 450V. I installed an old Hammond organ OT that was used to output a push pull pair of EL84 (the GA-8T uses a pair of 6BM8).
I am having two problems with the PS. Voltages are much higher than specs and there is a loud 120 hz hum. The output tubes had a 1.75K and 22uF/160V in the cathode bias. I have tried different value cathode resistors and have recorded the following V at pin 8 of the rectifier tube which schematic shows should be 270 VDC
cathode resistor - VDC
1.75K - 362V
370R - 311V
220R - 293V
The lower the cathode R value, the louder the hum. I increased both 10 uF PS caps to 20 uF but still have loud hum.
My tremolo is also not working but I want to focus on the PS first and try to get tube voltages close to the schematic with no hum. Any help and guidance is greatly appreciated.
Thank you! MarkO
1.75K - 362V
370R - 311V
220R - 293V
Thank you! MarkO
