Is there any reason NOT to add a 1Ω 1/2 watt resistor between Pin 8 on each 6550 and the 150Ω cathode resistor to make it easy to reliably check the plate currents on the tubes?
Leslie 122 Bias Monitoring Resistors
Originally posted by patlaw View PostIs there any reason NOT to add a 1Ω 1/2 watt resistor between Pin 8 on each 6550 and the 150Ω cathode resistor to make it easy to reliably check the plate currents on the tubes?
But you'll need to measure voltage drop directly across the 1R resistors and not from cathodes to ground.
- Likes 1
Or simply measure voltage across cathode resistor, calculate current from that, then divide by two to get current per tube. I don't recall ever having a bias issue on a Leslie amp.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOr simply measure voltage across cathode resistor, calculate current from that, then divide by two to get current per tube. I don't recall ever having a bias issue on a Leslie amp.
Most of them still don't know, it is just a fancy word to throw around.
I bet if you just mount a test point on the chassis wired to the cathode, and point it out to them, they will be impressed.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Originally posted by Enzo View Post. I don't recall ever having a bias issue on a Leslie amp.
I think that a common cathode resistor tends to increase imbalance of unmatched tubes.
Voltage drop across the cathode resistor is produced by the sum of the cathode currents, but doesn't mean that each tube contributes 50%.
- Likes 1
