Two(2) of the four(4) EL84s are red plating.. Turned on for about ten(10) minutes and V7 and V8 slowly increased red plating until I turned off. V7 was noisy when touched. None of other tubes including 12AX7s were noisy. Haven't taken any reading yet.
Peavey Delta Blues Red Plating
Does it have 8 tubes? Schematic attached has only 7. Check for bias voltage at pin9 of all power tubes.Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I would check the valves by swopping pairs over 4/5 - 6/7.
If the issue follows the valves, replace all four EL84s. If the issue stays with the valve holders, replace C32 & C35 both are 22n 400v (0.022uF)Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 3
Originally posted by g1 View PostDoes it have 8 tubes? Schematic attached has only 7. Check for bias voltage at pin9 of all power tubes.
- Likes 1
Agree with Jon, particularly with EL84's it is best to replace all four. They have fairly short lives compared to other power tubes, and if some are bad, the others are probably old enough that they are on the way out anyway.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Jon Snell View PostI would check the valves by swopping pairs over 4/5 - 6/7.
- Likes 1
