Little Marshall MS2
  • Little Marshall MS2
    Been searching to find the volume and tone pots for this little amp. Is there a direct replacement for these? A50K and B50K. I know it's a cheesy little throw away amp, but this is for a friend, and he has a sentimental attachment to this thing. Both pots are seized up so replacement is the only option. I tried to get the shafts freed up to turn but the pot metal housing broke on them. Thanks
    Need a picture of the pot to identify what it is.
ID:	968286 Click image for larger version
      Here they are....been looking through Mouser trying to find a match or something close.
        You will not find those in Mouser or many of the main suppliers. Here is a selection of B type, others are available but you may have to cut the shaft down to the length you require.
        https://www.ebay.co.uk/itm/282202446...Bk9SR4yN_NLlYA
          Originally posted by Jon Snell
          sorry but that random listing is all but useless.
          Like pretty girls answer me when I ask for their phone:"itīs in the phonebook".
          We need original pot pictures, case measurements and shaft diameter to pick a compatible one.
          Mini-knobs might have same split knurled shafts as other Marshall pots or not,check that.
            Those are the MOST common type available, generic "16 mm" case, probably 1/4" or 6 mm slotted knurled shaft, only shorter than average,maybe 1/4" long, measure diameter and length with your caliper.
            Best if finding exact same ready made; if not, a few minutes being creative with a Dremel will make most any shaft fit those knobs.
              It might be obvious, but whenever you need to shorten a pot shaft, find a way to clamp the shaft and NOT the pot case.
              Otherwise you might ruin the pot.
              Again: Don't rely on clamping the pot case when cutting the shaft. Hold the shaft instead - or at least additionally.
                Thanks guys!
                  This ought to get me where I need to be. The measurements are very close. May or may not have to trim anything.
                  P160KN-0QC15B50K BI Technologies / TT Electronics | Mouser
                  RV16AF-20-15K-A50K-3LA Alpha (Taiwan) | Mouser
                    Basically yes.
                    Each of them offers an incredibly detailed datasheet, with tons of options, as to shaft - collar - leg orientation, PCB/wire legs, etc.
                    I would open each and check bit by bit which applies.
                    I guess you want short collar,short shaft, simply because itīs a *pocket* amplifier so every mm counts, but match what you measure to what datasheet shows.
                    meaning you might not have to touch anything.
                    Worst case, Dremel is your friend .
