Vox AC30HW60 with excessive hum
  • Vox AC30HW60 with excessive hum
    Hi People
    Thanks for looking
    This one has got me scratching my head there is something i'm overlooking here
    The reported fault was turn on the sounds dropped in and out again and smell of burning
    Chassis check can see one grid stopper 100R burnt up
    Replaced for same and \ fitted new set of power tubes.
    Replaced fuse and turned on... excessive hum , Tested all channels working ok
    I removed the PI tube ( V7) ? No hum, If you remove all pre amp tubes apart from V7 and V5 Hum is present
    Remove V5 hum is still present but greatly reduced
    Checked with customer and prior to the fault , was working well and had zero background hum
    Stolec_AC30-TB (1).pdfac30hw60.mp3
    Replaced GZ34 and fitted all new pre amp tubes
    Checked all grid stoppers and 1.5k all ok
    Checked with another set of power tubes ( new to be sure)
    All Filter are F/T caps look ok and cant see any ripple on them
    I have piggybacked new caps on the filter caps still nothing
    If i turn the bass fully off and treble up full i can reduce it
    V5 pin 1= 273v
    pin 6 & 2 =172v
    pin 3 =173v
    Pin 8 = 1.18v
    cathode bias =10.4v around 80% Plate d
    EL84 grid =321v
    El84 anodes =323v
    PI tube pin 1 & 6 = 232v
    pi tube R71 = 52v
    Amp was purchased new and never been repaired til now about 5 years old
    The schematic is not the 100% version , but all seems to be the same
    I think the fault is coming from the V5 circuit ??? or am i missing something
    i was hoping to put up some scope pictures but mobile won't take a decent one
    Does the amp have a heater balance pot (humdinger)?
      50HZ or 100HZ? (60 & 120 in some countries).
        Hi Helmholtz. It does not . Looks like it has an artificial CT with 2 X 220r resistors..
          Morning i decided this morning to disconnect the resistor network for heaters and fit a humdinger temporary
          no change
          The picture below are from 56k on V5 and from the output speaker jack
ID:	974524 Click image for larger version
            Ok, so we have a 50Hz fundamental. Doesn't look like a ripple/filter cap issue.
              Ok, so we have a 50Hz fundamental. Doesn't look like a power supply issue.
              Thanks. I just can fathom it. i know valve amps have hum, but this is far to excessive ,
              I'm running out of brain thoughts for this one
                Did you find a solution to the hum issue? I'm having the same thing going on with my AC30HW60.
                  Is yours 50HZ? If so, check for heater cathode leak in one of the valves as the Dallas version of the AC30/6 or AC30HW60 sometimes didn't ground the heater supply.
                  If 100HZ check the EL84s are ballanced as they should be.
                    Yes the fundamental seems to be 50Hz (see screenshot). Interesting enough, when I unscrewed the supporting brackets for the power transformer, the measured SPL amp front went down from 58dB to 51dB. I screwed back everything and it stayed at 51dB. It's still a bit annoying compared to my AC30/6 TBX that doesn't have any hum and only measures around 42dB, which is a more tolerable level to me.
                    Any clues on this? Still haven't checked for heater cathode leak. This is above my knowledge and would have to bring it to an amp tech for this.
ID:	998462Click image for larger version
                      Ok did some more troubleshooting. Removed all the preamp tubes. "Dead" quiet. No hum. Put back one tube at the time and it seems to be something around V2 causing the problem/hum. Replacing the tube for a new one didn't help. Already tried to replace all tubes before anyway. Clues?
