Line 6 mkII hd100
  • Line 6 mkII hd100
    No sound all lights displays are on but no output??
    It's a Line6.
    Firstly check speaker connections and listen for a thump as you power it on/off. Check for a preamp out, with another amplifier.
    If it has the usual software issues and you cannot reset the software, send it to a Line6 authorised repair shop.
    http://line6.com/support/
      Also, make sure it's not in tuner mode.
        Check fuse F1: power tube heater fuse.
        Here is the reset procedure.
        Spider Valve MK II Reset Procedure
        Q: How do I perform a factory reset on my Spider Valve Mk II?
        A: The factory reset for the Spider Valve Mk II series is to hold the "A" button while powering the unit, then pushing the presets encoder twice.
