No numbers on the pan. Looks like it was replaced with a fender pan and now not working. Any help with the numbers or pan substitute would be appreciated.
Sun Sceptre reverb pan? Impedance/replacement?
Early models used a Fender tank, something like 4AB3C1B. Later models used basically the same thing with a little lever, accessible form the back, that would lock the springs down for transport.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
- Likes 1
Originally posted by The Dude View PostA schematic would help. We don't even know if it's solid state or tube driven reverb and can't even guess on a tank without estimating I/O impedances.
Sunn 100S-Sceptre-Sentura II Schematic.pdf
Cheers,
Tom
- Likes 1
Thanks, Tom!
I think a 4AB3A1B should work if that schematic matches (or at least the reverb circuit). The mod tanks have grounds that are configurable, so that might be a good option. Then again, the tank in the amp might be just fine. What number is on the tank that is currently in the amp? Or, what is the DCR on the input and output of the tank you have?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
