Sprayed all pots, jacks with contact cleaner, no change. Noticing that mp3 volume increase/decrease does almost nothing to the output of the amp. Nothing on visual appears wrong.
Eden E300 Low, distorted output
Check the effects loop connectors.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Check supply voltages. Should be around +/-15V at IC's on preamp board; and +/- some higher voltage at the power transistors, probably in the 35 to 80V range.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostCheck supply voltages. Should be around +/-15V at IC's on preamp board; and +/- some higher voltage at the power transistors, probably in the 35 to 80V range.
Q9,13,15,17(Power Transistors) -71/-0.5vdc
That looks like the standard Eden class B power amplifier. I doubt it is faulty however, they do suffer from poor switch contacts, contact cleaner will cure that and bad connectors on the interconnect leads.
Check the mute command line; Pin 5 of P2. Should be near zero volts or negative to open the Fets and allow signal to pass.
Originally posted by Jon Snell View PostThat looks like the standard Eden class B power amplifier. I doubt it is faulty however, they do suffer from poor switch contacts, contact cleaner will cure that and bad connectors on the interconnect leads.
