Eden E300 Low, distorted output
  • Eden E300 Low, distorted output
    Sprayed all pots, jacks with contact cleaner, no change. Noticing that mp3 volume increase/decrease does almost nothing to the output of the amp. Nothing on visual appears wrong.
    Is this a tube amp, SS ? Line in line outs?
    nosaj
      These look like Class D mini amps. website doesnt say much
        Check the effects loop connectors.
          Jumper them with a short cable.
          nosaj
            nosaj
            SS and one(1) XLR line out, speaker out, aux in, mp3 in, and phones.
              Photos
ID:	979053 Click image for larger version
ID:	979054 Click image for larger version
ID:	979055 Click image for larger version
                No dedicated efx loop
                  nosaj
                  No dedicated efx loop.
                    Check supply voltages. Should be around +/-15V at IC's on preamp board; and +/- some higher voltage at the power transistors, probably in the 35 to 80V range.
                      U1,2,3,4(ICs) +15/-15vdc Q8,12,14,16(Power Transistors) +71/+0.5vdc
                      Q9,13,15,17(Power Transistors) -71/-0.5vdc
                        That looks like the standard Eden class B power amplifier. I doubt it is faulty however, they do suffer from poor switch contacts, contact cleaner will cure that and bad connectors on the interconnect leads.
                        Check the mute command line; Pin 5 of P2. Should be near zero volts or negative to open the Fets and allow signal to pass.
                          Thanks for the info. Out of town working this week. Will check this on the weekend.
                            Originally posted by ca7922303 View Post
                            Photos
                            wow looks like such an old design for a current model. Im actually an authorized repair center for Eden (I think) and Ive never had anyone bring one of those in to me. Thanks for the pics.
                              Only P2 I'm finding does not have a pin 5 I don't believe. Can you verify where it is. Thanks.
