I had to change the jack for input 1. I decided to put in 2 switchcrafts and since there was no rush, I changed filter caps, cr13, cr14, r78, r79, r57, r58, r61 and r62. My problem is the amp is stuck in more drive when no footswitch is plugged in. It works normally with the footswitch plugged in. Voltages measure correct at r97, r78, r79, cr13 and cr14. What else do I check?
Fender-Hot-Rod-Deville-Schematic.pdf
