Greetings Folks,
I just signed up to this forum for soliciting help with troubleshooting a Fender Champion 30 non DSP version that I purchased used recently. PCB has a 1999 date on it. The seller indicated the amp would turn off after running for 4-5 minutes, but I wasn't able to replicate the issue. The amp runs fine but hums continuously irrespective of the position of the volume control knobs on either channel. Plugging in a guitar showed both channels are functional and switching between the channels was works, as is the reverb, but the hum presists.
To isolate the problem, I desoldered the power amp input AC coupling capacitor (C41), and reflowed all the TDA1514 pins but the amp continues to hum. Feedback resistors checked out ok and the voltage between pins 3 and 4 of the TDA is in the 6-7V. I attempted to mute the power amp by shorting pin 3 to the ground through a 100ohm resistor. This resulted in a reduction in humming while pin 3 was grounded but the hum returns as soon as the 100ohm grounding resistor is removed.
One additional bit of information that may or may not be useful. The 15V zeners 1N4744As appear to have been running hot based on the color of the PCB around them and I replaced both of them but I was surprised to note the voltage across them is 16.2-16.3V and they continue to run hot. The 27V system voltage runs around +/-26.4Vdc instead of 25.9Vdc as suggested by the service manual. I suppose this might be due to lower than expected load on the power supply.
I'm struggling to decide whether the TDA1514 is bad as it hums without a signal but it also appears to be functioning as I can hear sounds through the speaker despite the annoying hum.
Thanks for your help in advance!
