Brought up voltage slowly with Variac. No fan or lights coming on at any point. Was able to get some DC voltage readings on main board of about (125vdc) on right side of main board facing front of amp. Left side no DC voltage.
Ampeg SVT-7 Pro No Power On
Do you have a schematic that is correct to your board? IMHO these things are dang near unserviceable (unless this is different than the one I had). I think most people just replace the main board if they can be purchased. There are cascaded SMPS power supplies, multiple protect modes that aren't really documented, and probing is dang near impossible because of the tight layout of the FETS, heatsinks, and caps.
I guess you could check for shorted output devicesLast edited by glebert; 05-25-2023, 05:12 AM.
It is basically a Mackie 450Mk2 without the power factor corrector for more efficient use of power.
If you are not experienced with Switch Mode and Class D, take it to someone more qualified or you may kill it completely.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 2
Just a simple test, if the Mos Fet output transistors, Q10 - 13 are OK, check the secondary diodes on the power supply board. If faulty, replace ONLY with the original type and specification.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by glebert View PostDo you have a schematic that is correct to your board? IMHO these things are dang near unserviceable (unless this is different than the one I had). I think most people just replace the main board if they can be purchased. There are cascaded SMPS power supplies, multiple protect modes that aren't really documented, and probing is dang near impossible because of the tight layout of the FETS, heatsinks, and caps.
Originally posted by ca7922303 View Post
I recently was able to resurrect a 6 pro. Is there alot of differences between those two?
Originally posted by Jon Snell View PostIt is basically a Mackie 450Mk2 without the power factor corrector for more efficient use of power.
Jon, I can't find any info about Mackie 450Mk2, is that the name of a module from a powered speaker or something? I guess Mackie and Ampeg were both part of LOUD Audio back in the day?Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Here's the SMPS schematic (attached). There is a known issue with U2, but you'll have to troubleshoot to see if that is your problem.
0032543-xx.pdf"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Jon Snell View PostJust a simple test, if the Mos Fet output transistors, Q10 - 13 are OK, check the secondary diodes on the power supply board. If faulty, replace ONLY with the original type and specification.
D39/40/53/54(0.005v) diode test
D26/29/43/44/61(0.48v) diode test
D14(0.012v) diode test
D15(0.2v) diode test D16/17/23(0.4v) diode test
D12/13(0.5v) diode test
Z1/3/4/6(0.59v) diode test
D1/60(0.4v) diode test
D7/18/19/20(0.55v) diode test
D2/63/64(0.5v) diode test Q13 according to schematic is a 3904 and I'm unable to find it on board to test yet.
Originally posted by The Dude View PostHere's the SMPS schematic (attached). There is a known issue with U2, but you'll have to troubleshoot to see if that is your problem.
[ATTACH]n982936[/ATTACH]
The issue with U2 will not cause one rail to fail.
It is caused by either a damaged Shottky rectifier, a short circuit on the Power supply output lines or a short circuit in the power amplifier.
Where did you measure 125volts? The rail voltage is + - 55volts!
Edit; You cannot measure the output Fets with a DVM successfully, except for a short circuit.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
C177
Originally posted by Jon Snell View PostThe issue with U2 will not cause one rail to fail.
D12/60(-156vdc)
R46(-156vdc)
R49(+156vdc)
Q2(-156vdc)
Q20(0.00vdc)
Q10/11/12(0.00vdc)
Looks like anything northwest and west of T3 is (0.0vdc)
What can I use to measure the output FETs?Photo of positive probe on R46, black probe on chassis ground. Variac @ 115vac.
Looks like R46/U2(2)/C177 or C26 failed and we're replaced?
So ... the psu is faulty yes or no.
U8 U11 ... schematic of your board would be useful, save us guessing.
You state 156volts. From where to where?Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
