Marshall Code 25 Schematic
  • Marshall Code 25 Schematic
    Hi guys,
    My Code 25 amps has an issue, as after some minutes after power on (working out loud as normal), then it automatically going in silent. I found that it looks like my CODE thinks there's a headphone plug in, so it turn off the speaker. (I inserted my headphone, and remote it, so my AMP switched back to normal speaker OK).
    I'm looking for CODE 25 schematic but nothing so far. So I hope you guys could share the schematic with me. I thought it'll help me alot if I remove the headphone jack and re-solder it later if needed.
    Thank you so much,
    Best regards,
    Did you try squirting some cleaner into the headphone jack?
      I have been having this problem for a while now. It kept getting worse, now my amp is not useable anymore. Did you ever fix this issue?
