This amp uses a uPC1188H as the final output IC. Plenty available online and eBay. I know some replacement ICs can be duds, any known issue with sourcing these?
I have V at the IC and signal at the input, no output signal. As I was trying to get my probe on the pins I noticed that all the pins are loose from the IC housing. If you push down on the circuit board the pins move away from the IC housing. So I assume somehow they all broke away from the housing and the IC needs to be replaced.
Just looking for confirmation. Thank you
Schematic in service manual attached.
fender_frontman-25r_sm.pdf
