Not enough measurements. There are 4 diodes in the bridge, not 2
Mark Bass Little Mark III Blowing Fuse
Originally posted by misterc57 View Post
Example 20 VAC at BR1 AC and 10 VDC (plus and minus) BR1 DC outputs.
Originally posted by x-pro View Post
If there is a jumper in the CN9 connector, when 20V AC voltage with 60Hz frequency is applied to the bridge input, the bridge output (plus C39-minus C40) should be 2 times the voltage.
Originally posted by x-pro View PostAssuming the diode bridge is OK, if we unsolder at least T22 and apply 25V again, what will be the voltage at bridge pins 1-2 ?
So with 60 VAC coming into BR1 I see about 166 VDC at pins 1 and 2. Meter set to DC, red probe on pin 1, black probe on pin 2.
No excess current draw.
