Mark Bass Little Mark III Blowing Fuse
  • #31
    Not enough measurements. There are 4 diodes in the bridge, not 2
    • #32
      Assuming the diode bridge is OK, if we unsolder at least T22 and apply 25V again, what will be the voltage at bridge pins 1-2 ?
      • #33
        I removed T22 T23, now seeing about 50% VDC at the plus and minus pins of BR1 of the VAC.
        Example 20 VAC at BR1 AC and 10 VDC (plus and minus) BR1 DC outputs.
        • #34
          But I am not convinced that T22 T23 are bad.
          What is the recommended bench test for these?
          Thank you
          • #35
            R78 reads about 650K in circuit.
            • #36
              That's without C39, C40 ?
              • #37
                Thank you
                Why would you do that? If they are defective, just replace them.
                R78 - Should be 270k
                • #38
                  C39 C40 are still installed
                  • #39
                    Did you unsolder C39, C40? Did you check it?
                    • #40
                      If there is a jumper in the CN9 connector, when 20V AC voltage with 60Hz frequency is applied to the bridge input, the bridge output (plus C39-minus C40) should be 2 times the voltage.
                      • #41
                        Still soldered. Tested ok in circuit.
                        • #42
                          CN9 is jumped. Are you saying I should be seeing double DC of AC, example 20 VAC becomes 40 VDC?
                          • #43
                            yes
                            • #44
                              I should have mentioned that after removing T22 T23 there is no more excess current draw.
                              • #45
                                My bad. I was not paying attention to the BR1 pins.
                                So with 60 VAC coming into BR1 I see about 166 VDC at pins 1 and 2. Meter set to DC, red probe on pin 1, black probe on pin 2.
                                No excess current draw.
