Ampeg BA115HP Output and crackling/static
  • Originally posted by g1 View Post
    R66 still measures good and it's solder joints are good?
    If so, you have almost double the current running through it than normal. Measure resistance across C40 again. I would suspect you have another solder bridge somewhere that should not be.
    Pictures of both sides of the board might help.
    Photos
    • Those pictures are large files, but poor image quality. What is the name of the resistor near the 8 pin connector on the power board that looks overheated/burnt?
        R50(0.9k ohms) in circuit.
        • Need better quality close-ups of circled area, both sides of board.
          • And this area, both sides:
              which Ampeg model is this photo ?
              • Originally posted by x-pro View Post
                It is the same model BA115HP. (edit: incorrect, picture is from a BA210SP)
                • probably a different revision of the layout of elements on the board
                    What do you mean? That is the front panel board, not the power board.
                    • Post 259, second photo. It's different with the J28 connector
                      and the schematic shows a different arrangement of parts near that connector
                      • In principle, the scheme is consistent.
                        Therefore, as r1 asks, need a high-quality photo of the back side, where connector J28 and diodes D11, D12, C40, C39 are located.​
                        • Ok. I see the difference now.
                          If he takes a picture of his unit showing the area with connector, zeners and caps, that should work.
                            Sorry, my mistake. That picture in post # 264 was from BA210SP, not HP
                              Photos
                              • How about the trace side around the 8-pin connector on the power board.
