Originally posted by FredPhil
View Post
Blackstar HT Stage 60 / Need help on strange noise issue
This is what you got from the measurements.
That's not right.
The emitter of transistor TR4 is accurately probed at TP14, TP15 ?
Originally posted by x-pro View PostHow much does the voltage change on pins 1 and 3 of CON1 relative to Common of course when the standby is turned on?- Own Opinions Only -
It's time to end the tambourine dance.
There is an easy way to check the standby mode.
You need to unsolder TR4 and temporarily replace it with a simple switch. Solder it in the right places where the k-e is.
Then check the bias current on D27.
You don't even need to unsolder the TR4, you can solder directly to its pins.
The only thing is that when switching the auxiliary switch, you need to disconnect the common power supply to avoid accidentally burning the half-dead TR4.Last edited by x-pro; 12-06-2023, 06:37 PM.
TR4 emitter is connected to ground. So that's where your black meter lead should go.
Base and collector voltages should read negative.
- base = -240mV
- collector = -880mV
With Standby OFF :
- base = -2.14V
- collector = -2.78V
With or without TR4?
But from what you're saying, it seems that the next move now is to change TR4 and test again if I still get this bias current on standby, AND the crackling noise when using the amp.
Originally posted by x-pro View PostYou need to unsolder TR4 and temporarily replace it with a simple switch. Solder it in the right places where the k-e is.
But I think testing with TR4 and power tubes removed (post #27 ) will show everything we need to know.
- Likes 1
Originally posted by FredPhil View PostSo you're saying I should:
- remove TR4
- remove power tubes
- check voltage on every PIN of both power tubes (related to ground, I suppose)
Should I do this on standby or not? What measures should I get?
As said before, it should be a large negative voltage, i.e. significantly larger than - 50V.
