Floating paraphase again
  • Floating paraphase again
    There is a clear issue using floating paraphase to drive heavy loads as the signals appears very unbalanced. Different output impedances counts. What is the best way to cure:1. a build out resistor or 2. to modify the feedback resistor value in plate follower, please? Thank you.
    Are we talking valve or solid state?
    A schematic would help.
      Any imbalance should be correctable at the divider from the output of the first stage to the input of the second stage. I don't understand why there should be different output impedances. Assuming we're talking about a tube circuit all the paraphase inverters I've seen use a shared cathode circuit and equal plate loads.
      EDIT: I guess I'm confused. I don't know what exactly the "feedback resistor" at the "plate follower" would be. I'm thinking you're talking about the divider I mentioned above? I guess if there IS a feedback resistor the possibility of impedance imbalance does exist. As Jon said, a schematic will help.
        Here we go
        tube is a 6sn7. Measured voltage gain in actual circuit: 15.5.
          This design was tried and tested back in 1958. Doesn't perform badly from all accounts; Click image for larger version  Name:	Screenshot 2023-12-21 at 19.58.27.png Views:	0 Size:	728.4 KB ID:	991047
          66 and 22uF are a bit exessive for coupling capacitors don't you think?
            Thanks. There are 22nF and 66nF for outputs couplings (3x22 nF in parallel)
              This is a s.c. "self-balancing" paraphase using NFB from plate to grid at the second triode.
              The NFB lowers the output impedance of the second triode.
