So I have this ca. '67 JMI (UK) Vox Conqueror solid-state head, mk 1 version (i.e., OS/136 schematic).
I've just had it gone over, recapped as necessary. Don't think anything was done wrong as the rest of the amp works fine but the top boost switch apparently has no effect... ?!?
Couldn't determine/forgot to check if the top boost worked before the recap as it still sported original electrolytics prior to that and so was not fully operational (hence the recapping!).
Apparently, top boost in these amps works by shorting R46 (1k)... and the switch has been tested/works, as does C25 (1uF). FWIW, another well-regarded Vox tech says his experience is similar with one Defiant he encountered...
Pre-amp schematics for reference. Photocopy of an original:
A slightly cleaned up version:
https://www.voxshowroom.com/ct/schematics/SS.pdf
Normal channel in question:
Presuming it's not a factory/schematic error, outside of checking the switch, how do I go about troubleshooting and ultimately resolving this?
