Can someone recommend me a good Biasmeter for my Fender twin reverb and Marshall JCM 800? I purchased a 4 socket Weber Bias Rite 8 years ago which measured plate voltage and cathode current but 2 of its terminals broke up. Maybe bad quality plastic. I need a replacement that measures both and has at least 2 probes.
Need a good recomendation on a Biasmeter to bias my JCM 800 2205 and Fender twin reverb amps
The red knob twin already has bias test points.
How much do you want to spend for bias probe? They range from around $20 for kits from Mojotone, up to several hundred dollars like the TAD Bias Master.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Single octal bias probe for use with a Multimeter. I like this best. seems most durable. https://www.eurotubes.com/store/pc/bias%20probes.htm link has the fancy ones
I get that you could buy another bias probe, but the Weber is a nice unit. I'm not sure what "broke up terminals" the OP is referring to, but the only connectors I'm aware of on that unit are ordinary octal sockets, which could easily be replaced. Hell, if you're not going to fix it, send it to me!"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Originally posted by The Dude View PostI get that you could buy another bias probe, but the Weber is a nice unit. I'm not sure what "broke up terminals" the OP is referring to, but the only connectors I'm aware of on that unit are ordinary octal sockets, which could easily be replaced. Hell, if you're not going to fix it, send it to me!
Originally posted by The Dude View PostWhy not just fix it? Which terminals broke? Pictures?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
From what I can see, you have a broken keyway on one, and part of a female socket missing on the other (hard to tell for sure from the pics). If that's correct, I'd fix the broken keyway with one of these (just properly align the key and glue it on):
https://www.cedist.com/products/keyw...ce-octal-tubes
If you have the missing part of the female socket, glue it back on. If not, I'd replace the female socket with something like this (measure to be sure whatever you get fits):
https://www.cedist.com/products/sock...-mounting-hole
You'll have to figure out how to pop out the old socket, but they put it together so it must come apart. The sockets are likely just pressed into the tube. Just copy wiring. Wire the new socket like the old one. No rocket science involved.
Aside from that, you have 2 that are still good, so you could use it as is."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Yeah, now that I look closer, it also looks like pry marks on that socket. So, maybe someone already took it apart and broke a wire that goes to one of the pins. Probably too late now, but I wouldn't have taken that one apart and just put a keyway replacement on it. Whatever the case, it shouldn't be difficult to repair any of these problems."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 2
Did these ever work properly while in your care? If no, go find the smedly that sold them to you and work them over good. If yes,.. Why did you jack them up like that?"Take two placebos, works twice as well." Enzo
Originally posted by Jquijano View PostI took more pics so you can guide me fixing the terminal probes."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
