Peavey pvx p15 low output
  • Peavey pvx p15 low output
    I've got 2 Peavey pvx p15 powered speakers. I have the schematics but they don't really say what I should see at the power amp. I'm gonna set it up with a sig gen an a dummy load tomorrow But Peavey doesn't list a signal test.
    The power supply voltages at the power supply are good.
    nosaj
    What are the symptoms? (no sound, distortion, etc...)
      Passes sound but it's not very loud. I'll get a measurement on output. .
      what would an appropriate voltage of a 1k sinewave to inject directly into the power Amp?
      both speakers same symttom.
      Thanks nosaj
        I'd first check speakers. You could have speakers with shifted gaps. I couldn't tell you amp input level without seeing a schematic. If speakers check good, just bring up the signal generator slowly and see what you get.
          That one has a mic input? Shouldn't take much at the 1/4" in. Maybe 50 to 100mV ?
            ^^^^^^ That. I thought you were talking about going directly into the amp circuit on the other side of the mixer.
              I was talking about injection at the poweramp. Yo divide n conquer if issue was pre or post.
              nos as j
                I think, to get 230W (+/-38...39V) output power at the low channel output at 8 ohms speaker impedance, 1V RMS should be applied directly to the chip input.
                ​The heatsink on the chip is a must!
                  Originally posted by x-pro View Post
                  I think, to get 230W (+/-38...39V) output power at the low channel output at 8 ohms speaker impedance, ...
                  From +/- 38V I calculate a sine power output of 90W into 8 Ohm?
                    Incorporating the load into the bridge. The data from this?
                      Thanks, I missed the bridge mode.
                      Then theoretical output would be 360W.
                      But supply voltages will sag and limit available output.
                        They (datasheet) spec 150W per ch. at +/-35V, so I think 300W would be reasonable at sag.
                          A simple calculation from the datasheet.
                          420W(8) - sin. 58V(RMS) gain 36dB - 63.1; (58V / 63,1)=0,92V
                            Could i not just inject signal at connector on the preamp: hdr8sh pin 5 and pin 7 to go into the power amp?
                            nosaj
                              Yes. Note that the pre has a low pass out for the woofer and a high pass out for the horn driver. Be careful not to run too much full range signal on the HP out (pin 7). Horn drivers don't like low frequency. BTW: are both the horn and woofer low volume, or just one or the other?
