I have a Peavey Deuce II on the bench. Preamp voltage after the 2k 5W dropping resistor is 10 volts not teh 28 volts called for on the schematic. After the next dropping resistor, 470 ohm, I have 0 volts.Both resistors are good. All electrolytics have been replaced, all transistors and FET's test good or have been replaced, driver and power amp work fine with signal injected at the master volume wiper. I've lifted every stage supply resistor one at a time with no change to the low voltage condition. Any suggestions?
Peavey-Deuce-II-Festival-Schematic.pdf
