I have a 58 Bassman on my workbench. Changed some dried caps amps is sounding great but one 6L6WGB tube was redplating. I measured and whoah... 88mA on one
So
455V on plates
88ma / 66mA - tube measurement
I put 120k resistor instead of 56k but change is very small
Now: approx #1 is 65mA / #2 is 33mA now---- still too much!
Now: Plate voltage has risen up to 500V
Both 4,7k and 15k resistors are in specs.
Both 8uF caps replaced.
Quite confused.
I know that new matched set must be bought soon, but at the moment I want to make amp just playable within safe limits.
Is there anything I'm missing here? Usually, changing bias to a 10-20k more (or a pot, in series) resulted with quite hardcore range - and here, over double resistance and not much is changed.
https://robrobinette.com/images/Guit..._Schematic.pdf
https://robrobinette.com/images/Guit...der_Layout.gif
So
455V on plates
Quite confused.
