Peavey powered speakers converted to passive
  • Peavey powered speakers converted to passive
    Have a guy who has some peavey powered speakers with blown amps. What crossover would one buy to make this speaker passive?
    I see a lot on Parts Express but no clue which one to get.
    Thanks,
    nosaj
    Which speaker cab do you have? If two way, maybe tell us the woofer and compression driver.
    I have used the Parts Express Dayton crossovers - they work well. You can use them for both 4 and 8 ohm setups. I have also used the Eminence crossovers.
    Standing by to hear back ...
      Yep. Need more info. I'd look at the speaker literature and try to find a crossover that closely matches the design crossover frequency and power specs. That said, you may not even need a crossover. Some powered speakers use a single amp and a passive crossover.
        Peavey PVX P15's
          Looks like specs are 2.1K crossover point and 230W continuous. I would think something like this would work.
          https://www.parts-express.com/PRV-Au...859?quantity=1
          There are probably lots of others if a guy wanted to do some web searching.
            Good option Dude....
            The Peavey RX14 compression driver specs are here: https://peavey.com/product/rx14-driver/
            Looks like a 2Khz crossover.
            Perhaps you can use the Eminence PXB2:2K5CX 2-Way Speaker Crossover Board 2,500 Hz
            or maybe the Dayton Audio XO2W-2K 2-Way Speaker Crossover 2,000 Hz
