Crate GX-15 - Hums with radio station reception
  • Crate GX-15 - Hums with radio station reception
    I have a Crate GX-15 that makes a loud humming noise when turned on. I also hear a faint radio signal in the background. This is happening when there are no cables plugged into the amp.
    I read through the posts below and tried testing the voltage on the red/black speaker connectors. It reads zero which makes me think the amplifier (TDA2030) isn't the issue. The caps appear normal and soldered well. I can post photos if it helps.
    https://music-electronics-forum.com/...ate-gx15/page2
    https://music-electronics-forum.com/.../46220-​
    Any suggestions on how to troubleshoot further? Thanks!
    https://youtube.com/shorts/GISyA9Dqm...r5BGxvTYxWiZny
      Not worth the effort? Trash it?
        What position are the regulators in? Set them all to minimum and see how they react.
          What does the power supply voltage checks say? If you are hearing radio frequency then you hear some form of amplification. I would inspect the board for bad solder joints and anything else visible. Could be bad solder joints and bad ground connections.
            All the knobs are at minimum and the humming is still there.
              If you hear radio, it's likely a bad ground. Check all ground connections. Here's a link to the service manual.
              https://elektrotanya.com/crate_gx-15.../download.html
              You checked DC on the output. Now measure AC. If there is a substantial AC component, you could have a bad filter cap or one that has a cracked solder joint.
                Sorry, I'm not very good with electronics. How would I check the power supply voltage? Photos here: https://postimg.cc/gallery/V0KfBp5
                Thanks.
                  Ouch, at this point it's not even powering on. I think this one is done. Thanks everyone for the help.
                    See fuse
