Picked up a R25T combo with no speakers this week. I believe they were only made in 1960. I hope to get it operational. Looks like work had been started and then abandoned.
Original PT is gone and not a clue what is in there now. I was told it came from a TV. Choke and OT look original and OT tested okay with the 9V battery test.
No schematic has been found yet.
The amp has some encapsulated sections called erie packs. Supposedly there are 4 packs.
I plan to start on the power section. Test the PT which I have removed (not even sure it is suitable). I also will be looking for a schematic (any suggestions) I can use as a guide for the power section. a 1960 era amp using 5AR4, filter choke, (2) 6L6GC, (3) 12AX7.
Suggestions and comments much appreciated.
Thank you, Mark
Edit. I do not think the PT even has enough sections to support a guitar amp.
Thank you, Mark
