Originally posted by g1
View Post
![Thumbs Up](https://music-electronics-forum.com/core/images/smilies/icon_tup.gif)
Do not connect it!
First check the +B and -B points for a short circuit to the common wire (you can connect to the amplifier chassis). Capacitors C401 and C402 should be discharged (you can use a 220V lamp directly between the +B and -B points to discharge them).
If everything is OK, check all output transistors (Q313-Q320) and pre-output transistors (Q309, 310). Of course, for example, Q313,315,317,319 are in parallel, so if there is a short between collector and emitter, you will have to unsolder them one by one and check each one. Also check the transistors in the lower arm.
