Most of the time when I plug an amp into mine, if it's good, the light is pretty dim. But sometimes it is a little brighter but not totally bright. What does that signify?
Light bulb current limiter behavior
The brighter the lamp the higher the current flow through your equipment.
But, there is a problem ... the brighter the lamp, the more voltage across the lamd which means the lower the voltage on the equipment and that causes all sorts of odd annomolies.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Amps differ in current draw at idle. As amp and LBL are wired in series, their current always must be the same.
So more amp current means more lamp current. More current makes the LBL glow brighter.
Even hotter bias can make some difference.
Yes, different amps can cause different brightness. I usually use a 40W bulb in my LBL; my Rivera Concert lights it up more than my little 2x6V6 homebrew, which barely lights up a 100W bulb at all.
When I'm done working on an amp, I'll usually put it on the limiter with no tubes in. The bulb should barely light at all like that, because transformers don't draw current at idle with no tubes. Then I'll put the tubes in & the bulb will glow brightly for a second or two & gradually fade. If it gets bright & stays there, it's an issue, & we check the amp over again.
Jusrin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
- Likes 1
It's also worth remembering that a bulb limiter can cause a fault condition to occur with some transistor amps. Some will swing the output to one supply rail, placing a high DC voltage on the speaker output and drawing excessive current. It makes the amp look like it has a shorted output transistor when there's actually no fault at all.
- Likes 3
Originally posted by Mick Bailey View PostIt's also worth remembering that a bulb limiter can cause a fault condition to occur with some transistor amps. Some will swing the output to one supply rail, placing a high DC voltage on the speaker output and drawing excessive current. It makes the amp look like it has a shorted output transistor when there's actually no fault at all.- Own Opinions Only -
Can this also happen with variac at lowered voltage?
EDIT: For clarity, I'm talking about a load on the amp output- not the variac."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 3
Originally posted by Helmholtz View PostFortunately tube amps don't latch.
..and can't have DCV on the output.
- Likes 2
