Gibsonette Filter Resistor Cooking
Originally posted by g1 View PostJon's suggestion was to also move the OT feed to the other side of the 470, so power tube plate current is not going through it. Look closer at his diagram in post #10.
That would significantly increase hum with this single ended amp.
Unless it is shorted as you wondered about earlier. But I'm not sure if he tried it with the choke after rearranging the filter nodes, so the choke may not have been what was causing the 120 Hz hum.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yes, I agree. And for that same reason I think that choke that has been installed should still be preferable to a resistor.
I then followed the amp schematic that used a 12AX7 V1, removed choke from circuit as it was not in any schematic I found, installed the additional filter node with the 2W 470 R. No more hum but cooking the 470R 2W. Now have a 470R 10W in there.
How was the choke mounted? You should be able to tell if it was factory or someone did that mod years ago. A 60's amp should not have had a field coil speaker from the factory, 50's maybe. If you buy one of those cheap MK328 semiconductor tester, they will test chokes.
Originally posted by mozz View PostHow was the choke mounted? You should be able to tell if it was factory or someone did that mod years ago. A 60's amp should not have had a field coil speaker from the factory, 50's maybe. If you buy one of those cheap MK328 semiconductor tester, they will test chokes.
The choke on this amp is mounted on the end side of the chassis, bolted on one end, welded on the other end. Does not look original.
Originally posted by misterc57 View PostAn "early" version schematic of this amp shows a field coil and a 6SJ7 V1 tube. The V1 chassis hole on this amp is octal size, looks like the 12AX7 socked was not original.
The choke measurements indicate that choke is not shorted and should work well in place of the 470R resistor.
- Likes 1
Originally posted by mozz View Post14.6 ohms and 700mh sure seams shorted to me.
Those 5H chokes are typically wired after the screen node, so have to pass far less DC.
A lower inductance choke will naturally have a lower DCR.
