Happy New Year, folks!
Finally found a Marshall 1965B cabinet to match the A version I've had, and use a Traynor 20-watt Bass Mate head to drive 'em. Sounds pretty good, no ear bleed, but not quite as much drive as I'd like. Sounds much better with a Tube Screamer........
Decided that a Marshall-style 2204 might be the way to go -- most reviews I've read say that it's one of the better-sounding MV amps around. I can always cut the B+ with a high-wattage zener and use 6V6s to keep the power at the 20-watt level.
Couple questions:
What'd be a good source for a chassis. preferably aluminum? Maybe a Mojo Marshall JTM? I'm sure I can get a repro front and back panel set, or something pretty close. Cabinet won't be a problem.
Circuit card? Again, maybe the JTM 45? Figured I'd use Marshall-style filters and transformers.
Any suggestions are welcomed. Thanks in advance,
dB
Couple questions:
dB
