Does anyone know who makes/sells a 50K reverse audio pot with a rotary switch suitable for switching on an optoisolator tremolo in a Fender (type) amp? I've found I need that little bit of extra gain.
reverse log is pretty rare, although a 100k linear pot with a parallel 100k resistor will give an approximation of a reverse log taper 50k pot (graph it to see!)
Just replace the 50k rev audio pot with a 100k lin. That keeps the trem available all the time from the footswitch.
When I used a switched 50k RA pot (from weber), I found that the 50k intensity pot makes the tone go weedy that I never wanted to switch it back in.
I did some tests comparing the gain with a 50k load, 100k load, and the 440k load (of the 2 x 220k mixer resistors).
I think that with reference to the stock 50k load, 100k gave a 2dB gain increase, 440k gave a 3dB increase.
