Originally posted by Steve Conner
View Post
Question in regards to treble bleed resistor
There's no rule about how complex the circuit can be. You could use a 1000pf in series with a 220k, then parallel a 330pf across that 220k, then parallel that curcuit to another 220k resistor. Now you have a smaller effect from the 1000pf cap and all the effect of a 250pf (1000pf in series with a 330pf = 248pf). If that's too much 250pf you could add another, say, 100k resistor in series with the 330pf cap in the circuit. It can start getting silly, I know. But it depends on how far your willing to go. Different results CAN be had."Take two placebos, works twice as well." Enzo
The method that Kinman puts forward seems to be to match the bleed cap to the capacitance of the cable being used (eg ~1n2F), then add a series resistor of about half the pot value (eg 130k).
I find that a low capacitance cable (eg George L) makes this type of thing unnecessary though.
PeteMy band:- http://www.youtube.com/user/RedwingBand
I do not agree, i use low capacitance cables (ie : Sommer Spirit, 78 pf/meter, and i measured the same) and the effect of a treble bleed is still here.
At least with Teles, P90 and mini-humbuckers.
Edit : i use 4 to 6 meters, so it would turn in 13 to 20 feet.
Originally posted by Chuck H View PostThere's no rule about how complex the circuit can be. You could use a 1000pf in series with a 220k, then parallel a 330pf across that 220k, then parallel that curcuit to another 220k resistor. Now you have a smaller effect from the 1000pf cap and all the effect of a 250pf (1000pf in series with a 330pf = 248pf). If that's too much 250pf you could add another, say, 100k resistor in series with the 330pf cap in the circuit. It can start getting silly, I know. But it depends on how far your willing to go. Different results CAN be had.
Well, capacitence wise that works out a little better than my George L (~390pF, 15ft).
I've got 250k volume pots in all my guitars, except for the Les Paul, which has 300k pots on the Burstbuckers.
I think the combination of low capacitence cable and 250k volume controls helps to keep mid setting treble loss to a acceptable level, for me at least.
