The speakers in the amp are 8 ohm. They're wired in parallel, for a total 4 ohm load. If you're pushing the amp into overdrive, you want a pair of 8 ohm speakers that can handle at least 120W to 150W each.
Fender decided to get clever with the output jacks on these later Twins; you can run them with a four ohm load, an eight ohm load, or two four ohm loads. If you can find a four ohm speaker cabinet you can run it along with the internal speakers. If you can find an eight ohm cabinet, you can run it instead of the internal speakers.
I bring this up again because, while it is more stuff to carry, there is a perverse rule of speaker pricing where a brand new speaker with no cabinet will cost $100 each, but you can frequently find used guitar or bass cabinets, with speakers, for $100 total. This might only apply in the lower 48, I'm not sure.
It really sounds like with your playing style, a closed-back cabinet would be a better fit though. Shopping for replacement speakers is less fun when you NEED them because the old ones blew up.
